turning over no start
Ok folks this is really just to confirm im going down the right lines and am not missing anything :)
The new shorty was a non runner so started on that
thought she was seized but got her turning over now
getting weak spark from the plugs so will be using Bartflaster`s old spark plugs when i change them on sunday to try that
getting fuel up to the fuel rail and into cylinders so no fuel problem
therefore PTU should be ok just no hint of her trying to fire yet.
engine has been stood for a while by the looks of it. gonna do a compression test when i get the tester and see what im getting
Anything else i have missed i know you guys love these threads to get your brains working :)
Marty
Sounds like you're going about it right mate. You could try a bit of contact cleaner on the connectors. Have a look at the ptu make sure it's not gone green on the the connections.
yeah was gonna chuck on a spare ptu as well if i can get hold of one or use my spare series 2 one
Stick plenty of good fuel in her too! & de flood her it don't take much to flood .. So pull the fuel pump fuse & plant the throttle while turning her over for a count of 10seconds! This should de-flood her.
old fuel in the tank could be causing issues
possibly so yes might take a sample see if it burns :lol: plus change fuel filter may be water in the system now
could well be the ptu has packed up, If you have a spare i would try that 1st
+1. As you know i'm not mechanically minded but what you are describing is what mine did when the S1 ptu failed. Did all the same checks and cleaned all connectors but nothing until swapped to a known working ptu. Fired immediately and since upgraded to S2.
the obvious cure would be stop buying ratters :lol:
ha if it was a family version then i wouldnt of had it but i just saw this shorty sitting there saying fix me fix me
How many have you had :lol:
had a quick crack today as i had some used good spark plugs to try and a good ptu. Still nothing though. Also had my compression tester now too but im not sure if it is going on tight enough as all i can do is tighten it with the flexi pipe by twisting it. Was getting readings of 60-80 psi on the 3 i checked and that was on both banks will have another go or may need to get a draper extension for the tester that i have seen on ebay
did you test it with the throttle open?
yes
Daft question but is the battery OK?
ive got it hooked up to mine to keep the battery charging
Just a couple of ideas;
Check that the engine harness is correctly plugged in to the ECU.
Maybe Dodgy Coilpacks, but would be a bit odd if all of them had failed.
Are the injectors clicking away?
Dodgy engine loom, earths.
fuel is being delivered
coil pack resistance is fine
the car is turning over just not firing so it is all earthing out fine just not firing
this could be caused by really old contaminated fuel or low compression which is what im thinking.
Just doesnt seem to want to fire however i havent had a full day at it yet so
Have you done an ECU diagnostic check?
smithy
nope ill get onto it in the light :)
Ok a little update on this. Ive cleaned the ptu connections and used a good ptu from zedworld. Ive put 5 litres of new fuel in the tank however gauge was already showing half full but possibly old fuel.
Checked timing it is spot on
getting a spark and fuel pump is working fine.
She is trying to fire now im getting at least 2 pistons firing but not starting as of yet
Could do with draining the fuel tank really but there is 30 litres in there so dont really want to do that. Tomorrow gonna check each cylinder and make sure there is a good spark on each but other than that i think she is slowly coming back to life
Havent managed to do a compression test yet as the long adapter i got seems to be sticking so im sending it back and got a draper one on the way. would be good to get some fuel into the engine that doesnt come from the tank.
Old trick but dry pooring a little 3in1 oil into each cylinder then try her this would up the compression temporarily ? Just an idea !!
