Front door speakers
Got some 6x9s (Kenwood KFC 6907) and wanted to know whether they would fit ok in the front doors?
Is anyone able to help? Just thought I'd ask the question before taking the cards off.
also, I assume I won't need an amp to run these? I assumed they would run just fine off the headunit.
Should do, mine took a bit of modding but not a lot iirc.
Suppose it depends on the wattage if an Amp is needed?-I have a 50watt h/unit that runs 300 watt speakers fine.
That's the problem...I have no idea what the specs of my headunit are. It came with the car....I do have a 12" sub too which I'm hoping to stick in the boot so I guess I may as well invest in an amp to run both...
Do a Make & Model number search on the web for the specs.
Or post up here and someone may be able to help.
Good plan...this is what I found...
http://www.amazon.co.uk/Kenwood-KFC-6907-Car-Loudspeaker/dp/B0000YVDFM
Direction (1-4 Way): 3 way
Installation: Built-In
Installation Type: Built-In
Number of Ways: 3
Oval Size In mm: 155 X 225
Oval size (mm): 150 X 230
Power (Watts): 25+ watts
Speakers Format: Oval
System/Single Speaker: Single Speaker
Type of Set: Pair
Wattage: 200
Ways: 3
I know absolutely bugger all about ICE.. but I do know that one of my previous Z's I fitted 6x9s in the front doors, just cut the door card to suit and mounted them, they looked and sounded great. :thumbup1:
Cheers dude...I think that'll probably be the route I need to go down...just want to see if anyone has a definitive answer for me before I go mutilating the Zed!
they are usually pretty easy to fit there if you use a bit of mdf to pack inbetween the door card and the door you get a more secure fitting
Thanks bud...!
Number of Ways: 3
Type of Set: Pair
Wattage: 200
Ways: 3
Sorry bud, what I meant was to do a search for the Headunit specs!
found a pic of my old Z with infinity 6x9s in the front door :thumbup:
They don't look half bad! I might have go at fabricated these mdf 'sandwich' plates then! :cool3:
