more PTU questions...
I've just removed the PTU to see if I can check it out.
Have I got the old or new type (after recall) unit?
Here's whats on it:
22020 58S11
TSTR IGN UNIT
MITSUBISHI
J126 2301
The connectors are really mucky but would this cause it to run until warm then start stuttering and stall after a few backfires?
It did this when hot the other day and I had hoped all would be OK after cooling off but started her up from cold today and it ran until warm - about 10 or 15 mins and then cut out just the same. Looks like a permanent fault now.
My Z is a Jap import...
Chris,
If your unit is the big black mofo with a metal front and fins on it, it's the old one.
If it's a smaller unit (much smaller), with adapters to turn the old style plugs into smaller ones, it's the new unit.
Tis that easy..
Chris,
This is exatly what happend to me read the posts on PTU problems, me Jeff & AndyP have all the experience to you need.You can buy upgrade ones from the USA for $178.00 = £127.00 Good luck!!!
Ken
Following on from what Aaron said here's a pic':
Old on the Left New on the Right.
pic from http://www.aus300zx.com/
Trev
Yeah definately the old one - thought they would look the same just different part number.
I could do with swapping one over to test before throwing more cash down the Z drain...
If I know for certain it's faulty I might pull it to bits or send it to Andy"PTU" to fix.
Is that price from Courtesy in US?
Is there just one part or do I need a Jap/Euro part number?
