Keeping the Hicas light?
After eliminating the Hicas,is it possible?-would be good as a low fluid warning?:detective:
could you take some pics of what the box looks like. I also need to do this. didnt know if it could be done, i was just going to take my bulb out lol!!
Yeah!-was going to do the same,but the warning light is a good idea I reckon!
Box should be to the right of the ECU.reading more of the above,some say to leave the box in and unplug a small connector,looks like I'll be unplugging first!:ph34r:
Just to let you know the box is under the ECU,I unplugged the smaller plug and the light went off.Took the cap off the p/steering res,held vertical and the light comes on!-result.:biggrin:
Try looking at the Hicas Thread!:tongue_smilie::lol:
Found it :thumbup:
you lost me with this bit? Took the cap off the p/steering res,held vertical and the light comes on!-result.
Found it :thumbup:
Simulating the float dropping with low fluid level!-keep up!:lol:
Ahhhh got ya :lol::lol:
so one small box under the ecu and just one plug to pull out? to you take out the hicas ecu??
No left it there in case it buggered the normal steering! LOL!:chinese:
