February 13, 200223 yr Can anybody identify this connector and tell me where it should go. It has a black/red and blue/white wire going into it. I have just had an engine re-build and think they may have left something off because it is very clean inside.
February 13, 200223 yr Thats the connector which goes to the stock boost control solenoid on the passenger side - you might be able to see it, it's a cylinder shaped affair, will be just under the black hard pipe coming off the turbo.. If you're running a boost controller then it wont be connected up.. If not, you'll be stuck in safety boost on that turbo!
February 13, 200223 yr Thanks for the reply. Looked all over from the top but could find nothing. Looks like a jack the car up and get underneath job.
