protoj · Yesterday at 18:48 1 day
Hi all,
Have the anti lock light on all the time, have checked the ecu and its code 9 - motor / relay. Have changed the relays and still the same, can anyone tell me where are all the fuses that are connected to ABS? On another thread someone mentioned a 30amp fuse? any ideas greatly appreciated.
Garry
