- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
OK, the car is running (and it scared the sh*t outta me in Asda carpark earlier doing a nice slide..
).. but..
When pulling away (or revving the engine under the bonnet), as the throttle opens off closed, the revs dip right down, then race up to catch up to the throttle position..
This makes pulling away..... interesting!
I've checked the TPS (now set at 0.45v closed), but it could be the idle control valve not set properly? When I pulled the yellow plug off, there was no change in RPM, shouldn't it drop a little?
At idle, I can hear a hissing, but it could be coming from the AIV's, would that be right? (The hissing goes away if I pinch the vacuum line that goes to the stock boost sender & AIV solenoid (I think that's correct?))...
Ideas? suggestions?
Thanks in advance
Aaron
