how do i remove the center panel at the back?
also it will held in with some really sticky black stuff. once nuts are off push from the back of the panel.
Try not to use a screwdriver to prise apart, unless very carefull, as loads of guys have tried a bit hard and land up cracking it.
Warm the black mastic with a heat gun or similer , makes removing lights etc much easier . HTH
