front numberplate holder options?
if you can get the bumper flush, so no bracket is sticking out, (I removed mine and filled the holes when I was spraying it) you can stick your plate on with double sided foam sticky pads, works a treat, and looks much neater, no screw holes etc...
ahhh, just noticed you have a UK, so you have the UK holder plastic jobby, not too sure then, probably the same applies, but don't know as i haven't got one...! You might be able to get a replacement from someone on here?
As mine is a JDM the number plate was screwed straight to the bumper so what I did was to fabricate a black perspex backing plate which was screwed to the bumper and the plate was mounted on this, wish I had some pics to show it as it looks good imo.
