hicas an few other q's
hi all,
i have a light on saying "hicas" i hear its the 4 wheel stearing, any ideas what it would be an what do i have to do, many thanks,
also whats the switch top right hand side of auto gear leaver, the power an hold one,
thanks in advance
oh right i see, it did go out for a little wile the other day tho,
Check your Power Steering Fluid level. The same fluid is used for power steering and the HICAS system.
not a problem. it's the small round pot on the drivers side of the engine. (Just incase you didnt know ;) )
hi all,
thanks in advance
I agree, check your power steering fluid. And the button on the side of the auto shifter:
Hold: pulls off in 2nd gear (good for wet or icy conditions) and holds the box in higher gear for longer i believe so it wont change down so quickly if you put your foot down.
Power: what it says on the tin.
As an aside you also have an O/D button on the side of the auto gear stick you will feel quite a difference with it depressed or not, the box changes at higher rpm and she feels like a different beast.
thought ide add as ive seem a few people talk about this now, but my speedo dont work either, would my first place to start be getting a new speed sensor
