Can these be swapped for a 180 Mph?-please say yes as I have an offer of some!:thumbup:
surely the answer is yes, but they will read the wrong speed ie 120mph when your doing 180mph
isnt the point of 120mph clocks that they are a direct replacement for 180kmph
of course if its an import with 180kmph clocks, a speed converter and a mph sticker , then removing the speed converter and swapping the clocks will work fine although your mileometer will become a kmometer
[sIGPIC][/sIGPIC]
:death:-run that again! LOL!
I want to put a set of clocks,JDM 180mph which have been converted to Mph,in place of my 120 mph clocks, possible?-can't see a problem myself as all the VSS are the same signal so must be the clocks that interpret it?:hammer:
its just a resistor on the back of the clocks that change the signal . always worth doing a check against a sat nav to get them spot on though.
ah yes then
yes jap and uk speed sensors give the same signal (except NA ones) and the clock decides what to do with the signal
what i meant was the 300zx only came with 180kph (jap) or 180mph(uk) clocks. the 120mph is usually a replacement face plate in a jap 180kph clock
so if you take out a 120mph clock and replace it with a uk clock or a jap clock that has had the resistor mod done it will read fine
[sIGPIC][/sIGPIC]
ah yes then
Nice one,cheers fella!:wink:
