Rear speakers
Ok im after upgrading the rear standard speakers to something sounding a little nicer. Im wanting to stick with 6x4 as i think it would be too much of a pain to fit 6x9 so has anyone fitted a set of 6x4 that they have been mighty impressed with? Ive just had a look on ebay and seen some caliber ones from my memory they are quite a good make arent they?
Marty
if you have the original bose boxes fitted underneath go for 6.5 round instead . a much bigger choice and better sound
andyzx is right, if you can adapt or make room for some larger, round units you will get a better sound...having said that..I haven't! I replaced my stock front at rears with the latest JBL's. With all four matching, the sound has a nice balance and of course no need to carve anything up. If you are after ground thumping bass, these will not work for you, but if you are simply looking to upgrade what is in a stock Zed they give them a go.
The JBL's I used for the front are GTO628
...and the JBL's I used for the rear are GTO6428
Hope this helps.
