Compression test
Showing my nievity a little bit, but in the buying guide it suggests you get a compresstion test done. What's that all about and what readings should you get!?!
Thanks,
-Stu
Compression test will check the compression of each cylinder - It is a fairly easy job - no more than changing all the sparkplugs coz that is basically what you do - insert a compression tester into the sparkplug of each cylinder and then crank the engine.
What it will tell you is the and indication of the state of the Pistons + Rings, Cylinders and Valves / seats Etc, basically it is a good indication of the internal condition of the engine which can't be visually inspected without a teardown.
Nissan reccomends Compression figures should be :
TT:
128-171psi
NA:
142-187psi
Maximum difference across cylinders 14psi
If the test does fail you can do further things to see if compression improves to give you and indication of the problem.
Enjoy.
Z ya
Nico91TT
