electronic boost gauge
has any one fitted one of these. i just need to know is there anywhere you can wire in from under the bonnet. where do the electronic boost controlers get there feed from are they mechanical or electronicly fed.
Tony, think if i remember rightly, wired my Apexi down to the wires above fuse board in drivers footwell and took a feed from the headlight switch, boost pipe then went through bulkhead in same area.
Okay scrap that, heads up me arse at the mo, thought it said boost gauge, hmm
anyway mine the Apexi AVC-R is taken into passenger footwell and through the gromet behind inner wheel arch and up behind battery, although i seem to remember something being wired inside cabin.
TT.NET have a good write up for this.
is yours connected by a pressure fed pipe to the back of the gauge. or is it all just connected with wires smithy....cheers
IT TEES OFF FROM THE BOOST VACUUM PIPE FOR GAUGE ALONGSIDE PLENUM, APEXI HAVE FITTING INSTRUCTIONS ON THEIR SITE, ANY PROBS LET ME KNOW, SMITHY cool.gif
