Amplifier Setting Advise please :)
I know its not 300zx releated but would like a bit of advise on this car amp I have as I am a bit of a noob when it comes to car audio, and also where I'm going to be mounting it I don't think it will be accessable easily for a slight tuning session, so I would like peoples thoughts on some good basic settings please :)
I have a gto 6000 5 channel amp quite old I know but don't cost a fortune anymore :)
fronts are infinity 6x9 (3way)
rears are edge 6 inch components for mid & treble
In the boot is a 12" jbl sub which takes up a third of the boot.
the settings on the amp are
4. High pass filter which can be set at any freg
between 30Hz and 320Hz(adjustable)or variable
5. Low pass filter which can be set at any frequency
6. +6db(at45Hz)Bass boost,only Sub channel
and the switches hp (I presume high pass) switches on/off.
cheers
Edited by paulbrem
Im going to manchester on saturday so would be more than happy to call by and give you some free advice, its too complicated to put in words but quite an easy process to do
Paul.
Paul.
quite right lol, and remember allways keep your power and signal cables apart. and allways wipe front to back ;-)
Paul.
Really good of you to offer matey but unfortunately I will not be around as I'm working :( Although I am very appreciative of the offer, thanks :bow:
