prop differences
How do i tell if a standard prop is off a manual or an auto is there difference in length?
cheers
marty
Edited by Gonzo12c
yes mate, i beleive the auto is shorter? but i could be wrong - I know that they are different in length though.
This might help http://www.300zx.co.uk/forums/attachment.php?attachmentid=52161&stc=1&d=1264016765
http://www.300zx.co.uk/forums/attachment.php?attachmentid=52162&stc=1&d=1264016765
Now i know the pics are a comparison auto TT and Manual N/A, the lengths will be the same, but the spline into the gearbox differs between TT and N/A
how so? i fitted a tt box to my na prop with no problems! i thought the only difference between na and tt is the flange on the diff.
ahh well, I knew that someone with more knowledge than me would be along to correct me and give you the correct info.
lol i meant the difference is between the auto and manual splines.
Can someone take some measurements for me please on either manual or auto prop this is the info i have
from the front of the centre bearing, where the steel housing/mount starts (on top of the doughnut) to the very front end is approx 53cm there or there abouts
manual TT prop length (spider to spider)
1st half... 606mm
2nd half... 508mm
auto TT prop length (spider to spider)
1st half... 489mm
2nd half... 508mm
manual NA prop length (spider to spider)
1st half... 606mm
2nd half... 539mm
auto NA prop length (spider to spider)
1st half... 510mm
2nd half... 539mm
distance between yokes
NA... 71mm
TT... 80mm
a manual prop will fit into an auto box but, an auto prop will not fit into a manual box without modification
I have at the moment an N/A auto. I have a manual front prop piece and a 1 piece manual prop for when i do the conversion.
Looking at the measurements of both the auto and manual prop, the manual prop is longer, so my question is, how can a manual prop fit an auto box?
Graham
Graham
i'm on about the splines, not the length ;)
