possible prop shaft problem
I've got a manual TT & the front half of the propshaft appears to have something loose inside it! It appears to be something that slides up & down the inside of the prop. Is this normal?
Shaun
if you meen up and down as in the gearbox in and out then yes there should be slight play as for something inside the prop all i know is tha there is rolled up cardboard inside all of them (a sort of sound deadening)
markzzzzzzz
