Stack Boost Gauge - How Does It Adjust?
My aftermarket Stack Boost Gauge does not rest at zero, it is under at approx 1.5 out :thumbdown:
I also know it's 'out' as my EBC records the peak and is always a higher reading than what my eyes see on the gauge :pinch:
It is this gauge
http://www.merlinmotorsport.co.uk/p13905/STACK-BOOST-PRESSURE-GAUGE--30-TO-+30PSI/product_info.html
As the thread title hints - how can I get it or adjust so it sits at zero.
Thank you. :helpsmilie:
you can take your gauges out, i.e. the dash cluster, then pop the perspex front off, 2 screws hold the boost gauge in from the back, and bend the needle mechanism a bit, it is very delicate tho, the 'stock' boost gauges are pretty innacurate anyways, but i can understand you just wanting it to look right, i had to do this with mine.... be gentle tho, don't break it!!! *disclaimer*
might be able to just bend it a bit from the front without removing it, can't remember, i'm very tired!
You must be tired :confused1: it is the STACK gauge on my A pillar and not the STOCK gauge I am having a little bother with :hammer:
hahahaha, fair do's, I thought you were the tired one and couldn't spell 'stock' :oops: :) I'll get my coat.......
No wonder you are or get tired 03.52 :huh: :huh:
It is this gauge
Did you connect with a T piece when you fitted your STACK gauge? The connections may be a little loose so your not getting the right vaccum? Just throwing suggestions in!
yeah, I work daft hours mate, was finishing off a Mk1 punto with a Coupe 2.0 turbo lump conversion till 3 int morn :sleep1: it don't half shift tho :)
