Wolfrace Shark Alloys
Hi guys,
Anyone on here with these fitted to their Z ?
I have 8.5 s just fitted to the fronts and 9.5 on the rears, they came with the 2 spacers to fit on the front wheels for clearence, do you need different spigot rings ? as when the tyre place fitted them for some reason they removed all 4 spigot rings and then put the wheels on without them.
Please see my other thread about wheel vibration
Help needed urgently
Chris
The spigots take the play up so go back and tell them to replace them , or your wheels might be of center ,
Hi bud,
Do the spigots that are on the hubs now have to be changed for different ones then, if they do can you tell me where i can get these from.
Cheerz
Chris
I got mine as a full Kit with Spigots and nuts. Not sure what spigots you have at the minute but since they are aftermarket wheels i'd suggest changing them anyway. Could try contacting wolfrace direct or try a seller on e-bay as they will probably know what spigots you need and be able to sell you a set seperately.
I think these are excellent looking wheels for the z.
When you get your spigot rings would you please post up the size here, as I think I also have a slight vibration, with my (identical to your) wheels.
The 2 dimensions (inner and outer diameter) should be stamped on them.
