fiat coupe 20v NA
does anyone know these cars? got a major pain in the rectum with one, wont start, got ideas, just need someone who might know them, can't be bothered with fiat forums, they all seem like stuck up turds, not like us zedders :punk:
When you say it doesnt start, have you got some more info.
Does it turn over? Flat battery or dead starter motor or imboliser problem
Is there fuel getting through? If not could be a fuel pump or again imobliser problem
Is there a spark? low battery tired spark plugs or fault coil (s) not sure if they are individual
Im an Ex coop owner but we need more details like chris said.
fccuk is the best place to ask tbh :)
I had the same thing on one I had, found out it was the crank shaft sensor. If you look on line you can do a dash bored flash test.
ive had one. hated it.
Fix It All the Time
mind you, at this rate im not getting much more luck with the zeds!
Fix It All the Time
lol
Feeble Italian Attempt at Transportation
Failure In Automotive Technology
Fix It Again Tomorrow
Any my personal favorite
Fart In A Tin
lol
Fart In A Tin
:lol: :lol: :lol: :lol: :lol: :lol:
hahahaha....
well, turns over fine, never tries to fire tho, just fresh air coming out the exhaust, fuel pump is priming, but none getting to the cyclinders, i.e. the injectors are not opening, but there is pressure. no spark that i can find, but i'm sure it's not the immiobiliser. the code light goes out as it should, but the injector light stays on. i think it is the crank sensor aswell, but am i right in thinking it is located behind a cam pulley and it's an engine out jobby?
i'm not sure mate, think it may prevent the car from starting when it detects a fault...
it has started tho, twice, just randomly, drove it for about half an hour and never missed a beat, turn it off, then just wouldn't start, has done this twice....
