water leak comes back to haunt me.
Well progress, the hesitation issue has now gone. car running smoothly again, then today got her up to temp went to move her, and low and behold a bloody swimming pool forming under the car. turned the engine off and checked.
Water leak is back, but noticed it does it when the engine is warm, when its stone cold, it doesn't, so going to empty the system out over the weekend and check the top rubber pipe work. also going to get the rad out, take the plenum off, clean everything check the water pump, flush the radiator through, and if needed change the water pump, top inlet pipes, clean all the radiator rubber hoses, water by pass, and polished plenum on. may as well as shes going to be off the road for a few days chasing this water leak. ill update this thread with photos, now I've found my camera, and get a walk through up as well while I'm at it.
detailed pictures at the rear of the engine would be nice bud when the plenum is off? :thumbup1: thats where mine is leaking and im going to try and do it over the weekend, (if i get a minute or two!!) i had a good idea where my leak was coming from due to steam, do you not get a bit of steam?
Yeh , do plenty of pis if you can vods, I`m doing the plenum off jobbie soon
wow i go sleep, and look at the interest I've stirred, don't worry ill be getting loads of car porn pictures, and yes Jeff, you were right, doing a flush made it worse but at least its nice and healthy water / coolent.
As for the hesitation issue, i ran down to the car the other night to try changing over the PTU, changed it over, tried starting the car, but she wouldn't fire up on the new PTU, so put the old one back on after cleaning the connections. must of caught it when doing the power steering pipe, as she hasn't been hesitant since.
and yes Jeff, you were right, doing a flush made it worse, but at least its nice and healthy water / coolant
5190GA5QWML._BO2,204,203,200_PIsitb-sticker-arrow-click,TopRight,35,-76_AA300_SH20_OU02_.jpg
Jeff TT
what's this? "Give Me a Clue" with Una Stubbs? Jeff's not allowed to talk, only mime via pictures he stole from the internet?
glad your hesitation's gone Ian - shame about the leak as I know sometimes theyr'e a pig to ID!
Edited by EvoluZion3
Jeff TT
