How to connect turbo timer
where I need to connect wires to key ingision? I need to find wires with 12v, ig1 and 2ig can anyone help me?
  • Replies 26
  • Views 924
might help if you said the make, someone might have the same one they have wired up so would be able to help you better.
I litterally guessed mine and kept trying different combinations and eventually it worked here's a walk through on sxoc for wiring I used (similar)
:mellow::confused1:
I got Apexi auto turbo timer and it is 3 wires red green and blue and thats what i need to connect
This is what I wrote on my iPhone as I was fitting it, hope it helps
red wire went to Thick White with red stripe wire (on tt harnis) was 12v constant
blue wire went to White wire with thick blue stripe 12v acc tt harnis
green went to black wire with red stip 12v ignition tt harnis
:mellow::confused1:
Sorry, yea my bad, that makes no sence :P
I will try today and will tell you if that was helpful mate, thanks.
no mate i try to do that but is not wires on my car as you said:confused1:
Wait, I'll go outside and have a look under the dash... Brb
Its been 2 mins already come on, Slow ass lol :D
Green went to solid black,
blue went to blue, and
red went to white
that's how my hks turbo timer is wired in, that last post was clearly the useless sxoc walk through
Lol!!!some idiot used zipties to hold the tray under the dash on... Oh wait that was me ;) lol!
Did it work then?
thats looks clear I will try now and I will tell u if thats ganna working. thaks mate :rockon:
I try to connect red, blue and green wires as you said. power is on turbo timer but is still something wrong. Where you guy connected ground to ecu? to o2 ground or just to a black ground?:sad: sorry about all the questions
I fitted one of these the other week! Have you bought a Harness? You need to connect the white and grey wires to the correct part of the ECU, I can't tell where exactly, you will need a diagram which is on the Apexi site (there is also a thread sticky on the forum too) if you haven't got the fitting instructions. The Grey wire then runs to the hadbrake.
http://www.roadraceengineering.com/instructions/apextimer-wiring.pdf
http://www.xspeed.com.au/manuals.php
HTH?
Edited by WelshZ
Enter a link!
I just shoved the neg on a bolt to the chassis, handbreake wire to the handbreake switch and the yellow wire went in with the green
HTH?
o2 sensor, handbrake, and ground is don't. just need to connect correctly 12v, ig1, ig2 straight to ignition. I connected everything, looks like turbo timer is working but than I take out the key engine turns off.:crying:
I'd get yourself a Harness mate! You plug the harness in to the ignition plug and the turbo timer relay wires plug straight in to the extra wires running off the harness. It cost me £12 or £15 (can't remember) for the harness. It will save you splicing through the wires if you have one.
Mate I cant find that harness for for apexi turbo timer.
Handbreake wire?
I think most harnesses are the same im using a hks harness with a greddy turbo timer .
I got it from one of the traders on here. I'll have a look through my inbox and let you know.
Handbreake wire?
Yes! the grey wire that comes attatched to the relay box. You run this to your handbrake and if the handbrake is released whilst the turbo timer is in operation it will cut the engine. Safety feature!
I connected everything guys and looks like is working but then I take out the key engine turns off straight away :(
There has got to be a wrong wire connected somewhere buddy. I got the Harness from Dan at DTA (Uk) post a thread for him in the traders section. It cost me about £20 inc delivery.
Matt
