clutch master cylinder
mine leaks inside the car from the seal, so i bought a new one from ebay (did not ACTUALLY go through ebay as i needed it for dwyb that was 2 days later)....
didnt actually turn up in time :(
1f0b3612.jpg?t=1287430004
mines the one on the bottom, the one at the top is the one i got sent..
whats (remember my car is NA the engine is TT so is there a difference in NA & TT master cylinders?
or have i been sent some random one for some spurious nissan??????
Does your original NA have ABS? Im not sure if there is/should be a difference but TT's had ABS as standard IIRC and NA's did not.
The top one is a twin turbo, there is no operating rod coming out of it as the TT uses a booster.
The botom one is non turbo with operating rod beem part of the cylinder, the two cannot be swapped.
Jeff TT
Bugger.... Anyone wanna swap? My feet are wet and the paints coming off my shoes... Lol (thankyou jeff your a legend ;)
So what's the difference between them? How can I convert from na to tt? Do I need a servo?
yep you`d need to fit a servo, i`d just get a new n/a one or a rebuild kit from one of the traders.
Ordered a new na one from jap parts via jeff £81 thanks ;)
