Not quite sorted.....
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Well as some of you may have seen, i had a problem with my auto box not selecting gears recently. I followed some advice from you guys and swapped fluid, no difference, then took of sump and cleaned out strainer, and replaced the fluid again. Hey Presto she worked, drove a couple of miles last night no problem so i took hr into work today but i noticed that at low speeds, (ie 1st and 2nd gear) she is changing gear ok but there is a slightly high pitched whirring noise (also in P when you rev - same noise) This noise is not noticeable when in higher gears.
When i say she is changing gears ok, when i start her up and stick it in D there is more of a noticeable jolt than before when she engages the gear and likewise when the box goes from 1st to 2nd there is more of a noticeable jolt too.
I think i might have put too much fluid back in this time, as indicated by the dipstick.
I was going to go through the whole process again, (ie take off sump and clean out strainer again) which i thought might help as maybe the fluid not drained out last time might be causing this, but does anybody have any ideas as to why it might be doing this?
Thanks in advance
Edited by Pablito
spelling
