protoj ·
Is it "safe" to change the auto tranny fluid in a 1990 TT which (to my knowledge) has never had a change in it's life?
The gear changes are a bit strange (2-3 seconds to change up from 2nd) so I was going to try a fluid change.
Any thoughts?
Ta.
JonnyC
