the problem
hi there do the front wheel bearingz go on the zx?
i have a lumpy drive i can feel the viabration is that the left rear bearing?
the mechanic who drove it also said the propshaft uj is messed up its got play in it and it vibrates as you pull of which i dont feel :S can that be true?
hand brake is it shoes that might need tightening?
Prop will probably be the bearing exactly what mine is currently doing. Zedworld sell a balanced one piece which is the way to go for that.
is it during braking or normal driving coz as iv learnd the discs are prone to warping as well as the anti roll bar links going
charles i didnt exactly get you there prop shaft bearing you think might be gone or did you mean teh wheel bearing is gone? cheers:turned:
zhoody the disk ive ordered of ebay there cheaper then anywhere else and pads from a local store for slowing down you will feel the problem is pedal will be up and down and also the steering will shake my problem is taking of i feel an issue, then on the move the cars like its un even from the back
sorry man didnt read your first post quite right ignore me..lol.
listen to sir charles
ย
its defantly your prop bearing i'd say mate, fairly common, does it vibrate less after driving a while? i had a bearing go on one of mine, it did it a lot less after doing a few miles. anyway, im almost sure its the prop from what your describing.
ย
You would hear a wheel bearing knocking all the time normally in my experience with them.
ย
There is a fair bit of play in my prop because the centre bearing is shot but mine only knocks when pulling off uphill because I'm carefull pulling off any other time until I get it sorted. Otherwise there is very little vibration. Maybe your bearing is worse than mine
