Fault code to puzzle you
So you don`t see this often, ConZult screen shot below from a Jap spec TT with a slight running problem (backfire, will reveal later) any thoughts or theories?
Jeff TT
  • Replies 35
  • Views 1.4k
Dont tell me, the injector was firing when the valve was closed?
Effectively yes, there was a degree of overlap caused by the bad cambelt timing, but also there was a faulty earth return on the afm plug causing a corrrupted signal to enter the ecu, this in turn was keeping the injectors firing non sequentially, a simple repair.
Jeff TT
Edited by JeffTT
Jeff TT
Well with out being near the car, i wouldn't of known about the faulty earth return lol
Also grats on passing the 2k post mark (might even be the second time lol) but grats anyway :D
Take your point, this is exactly the issue we have with phone call tech help anyhows you guys are too clever so have to hold a bit back :D the point however I should have made clear is there is no actual genuine fault on the zed that can produce injector leaking error code, so its always a corruption error, so even if you had a leaking injector this code would not pop up, fault diagnosis can be very tricky.
2k mark well I seriously did not notice!! second time around......probably:rolleyes:
Jeff TT
Edited by JeffTT
