adjustable control arms help?
the previous owner of my zed had new kyb shocks all round, drift spec tension rods and adjustable control arms. all has been good drivers is fine. Passnger side is the issue. i have noticed a few things.
1. The front arch liner has been worn when on full lock to the right by the tyre, and slightly sliced the expansion bottle, causing slight water loss also the same on the front rear liner.
2. looking at the control arm is seems to have been put in the same as the drivers side???? is this right??
I know the zed had a front end crunch on the pass side, but had been repaired at zedworld, i think.
Has anyone any pics of the passenger side control arms fitted, so i can fit them properly, before i get a full alignment done
Hi stu if you want i can do the bits for you , during the day , bit bored lol
