Engine management light
Yellow engine shaped light 5th from left as shown in diagram below
Jeff TT
Mine didn't come on with ignition, did you have to remove it when the lamb sensor was disconnected? Cheers jeff, Dan
No reason for the light to not come on except the bulb has gone? and that would be rare indeed, the light is controlled directly by the ecu so the only next check is the bulb.
Jeff
Ok Jeff, thanks, also noticed I have no seatbelt light or "Security" light, would these too be just down to blown lamps?
Aha! that maybe the clue we needed, there is a seperate connector that plugs all of those lights in, take the top of the dash binical off ( two x screws) and look at the left hand side, should be a medium size white connector fixed to the dash cluster, check it is plugged in, I can post a photo tomorrow if you need it.
Jeff
