update on my swb restoration
for anyone who is interested here are a few snaps of where im up to on my restoration/customisation. ive mainly focused on the engine bay as that is what im doing at the moment
engine bay was taken back to bare metal, this is just about the last of it
pas pot has been moved to here
to here, hicas has been removed, inner wing deseamed/smoothed. all holes have been welded up (except a few that i still need)
same goes for this area too, there will be nothing here except the brake servo/clutch master cylinder
Alot of work has gone on in this area, the battery tray has been removed which revealed a few holes where the battery had leaked, the upper suspension mounting had also had a bit of a bash at some time and had distorted the reinforced panel. i cut out the whole panel in this area and replaced it with one cut out of my breaker. all spot welds drilled out etc and welded back to look factory-also checked to correct chassis dims. you can see which panel i mean as its red (weld through etch primer)
same goes for the passanger side, i have replaced the headlamp pod aswell, it had been repaired to a good standard but i was not happy, it would appear my breaker had a bad bump (bent the chassis rail) but they had replaced the headlamp pod with a new nissan item so this was grafted onto my car aswell. all looks perfect now. the fusebox will go under the nose panel on the inside of the chassis leg opposite the pas pot
both chassis rails have been given the smooth treatment too
fuel filter has been moved down here where all the aiv stuff used to live, the stock fuel lines have been tweaked to pop up under the chassis rail where you can just see the little notch. the fuel lines will then go up through the panel above (where battery used to be). ill use a jic bulkhead fitting here so in the engine bay i will have aeroquip type braided hoses with propper connectors in stealth black onto an adapted fuel pipe.
tomorrow i will spray the bay in a final coat of etch, then seam seal a few bits. might even get on to giving it a coat of 2k high build. Colour will be pure gloss black. im going for a very stripped out look in the bay, no wires showing and nothing but the engine to see. colour scheme will be stricktly black and silver/chrome/pollished aluminium.
hope you enjoy.
  • Replies 279
  • Views 28.8k
  • 3 weeks later...
well ive not done much outside on the car recently for obvious reasons, but i have done a few bits. no pics sorry so ill just do a quick update and some more pics in the week
bought some of carmads new swb skirts. ive had a quick offer up but not really tried to fit them, sorry for the delay mate but ill get a few pics up
ive also done a few more bits of interior including a new centre console cover, handbrake and gear leaver gaiter.
just started my big brake conversion today as well, picked up a brand new set of brembo 4 pots on sunday and im going to be fitting some 345mm discs so should be sweet, ill make a prototype bracket tomorrow to see if they squeeze under my 17's but initial offering up looks positive, ive got access to a few set of these calipers so if anyone is interested i could be persuaded to make up a few sets if anyone is interested (as long as this is allowed by club rules)
the discs are only card cutouts at the moment but they look amazing filling the whole wheel out. i dont think i could fit any bigger inside my wheels though.
ive got next week off work so i hope to get some real progress. the plan is to have the car back on its wheels at the front and have the front end just about done so i can turn the car around and do some bodywork to the back and passenger side.
  • 4 weeks later...
erm a bit, its been cold in my garage so ive not done too much. the discs for my big brake conversion should be here tomorrow so ill post up some pics, i should also get some bits back from chroming soon aswell. i think ive hit a bit of a wall finding it hard to work up the enthusiasm to do much though:thumbdown:
  • 4 weeks later...
yes actually mate,
quite a few shiny bits acquired/made shiny. ill try to get some pics up
as promised here are a few more pics of my work
ive had real trouble getting out to the garage and being inspired to do anything but in the last week i have seem to have found some enthusiasm, im sure its the weather.
work still continues on the front suspension and engine bay, im hoping to have it down on the front wheels soon though.
im nearly there with the brakes now though, made up a trial adaptor to fit my brand new brembos and the largest disks i dared to squeeze under my 17's
lookes a bit like this
not alot of clearance between the rim and caliper as you can see
here is the new disks compared to the old stock items, they are 345mm
just getting some plate plasma cut at work so i can make the real adapters with a few slight tweaks, i will just need to tap them and get them plated
while i was at it i also did a quick check of the stance, wheels are looking quite flush but i will make up hubcentric spacer to bring them out a further 20mm or so, the wheels are 9" et40 so 20 should bring them about bang on
also cleaned up one of the side mounts, the only thing left to do here is the washer pump.
here is a quick shot of the cross member, most bits done, just need to sort out the pas return pipe. the radiator looks a bit grim but my new japspeed one turned up today so ill post up some pics once i fit it tomorrow.
finally a very blurry pic of the counter sunk strut top bolts, they are usually studs but i think thats going to look a bit crap so im adapting my tein pillow ball top mounts
tomorrow ill trial fit the rad and take some pics of my newly reconditioned front hubs
and a few more random pics i may have missed, generally of carmads excellent new skirts
Awesome work as always. Enjoying watching this come together, going to be absolutely stunning. Top top work mate.
looks fantastic mate, keep up the good work! :thumbup1:
That's great buddy, always a pleasure to read through this thread and see what you've done next! :)
Keep up the good work, it is crap but i got a gas bottle powered fire which took the chill off and made working in my garage more liveable
looking good, thanks for the pics. i actully sanded the skirts back to the size you gave lol..
they are a little thicker on the ends when i pull them out of the mould so im happy with that :biggrin
  • 1 month later...
Any updates Pete? This is going to be an epic Zed.
BLOODY HELL!!!
Only just seen this thread!!
Great work buddy. I love the engine bay detail - less is more, less is more!
Should be an awesome car when it's finished.
  • 1 month later...
well its been an age since ive updated this and to be honest ive done very little due to refurbing the house/work/bussiness and a little bit of lack of enthusiasm. however i have spent the last two evenings under the car starting to remove all the underseal, i wasnt looking forward to this as its real slow going and a horrid job but ive done most of the drivers side floor pan now. no pics but im sure you get the idea.
to my surprise ive found very little rust, most rust bits have been caused by scrapes or poor jacking
for an idea of the finish ill be going for have a look at this
http://passionford.com/forum/pictures-video-and-photoshop-forum/336624-pics-of-restored-cars.html
i dont think you can beat the ford boys for the quality of restoration and attention to chassis detail.
never seen a 300 done to this quality, anyone else?
my aim is to try and amaze Jeff when its back on the road as i plan my first run to be a shake down run to zedworld.
now where did i put that elbow grease
work has continued on the underside of the car this week. again sorry but no pics but ill get some tonight.
the main news is that i have built a car spit so i can work on the underside while standing up instead of on my back, it bolts on to the bumper mounts.
once im done with it ill give it to the club so that more zeds can be saved
I'd love to borrow that. Great way to find loose change!!
I take it you need to remove the bumpers?
Andy
yep, the bumpers need to come off.
i would also advise the engine, rear subframe and most of the body panels for that matter. even with a stripped out car its a bit un nerving having all that weight suspended by two bars
  • 1 month later...
lots of work has been going on. ill have to sort out my photos and update tonight
  • 1 month later...
I haven't forgotten about this!:biggrin:
