Gearbox oil filling
Does anyone know how to get gear oil into a manual box? I think it goes in through that metal pipe at the top but I'm not sure!
Thanks,
Shaun
isn't there a plug on the side of the box, that also acts as the level indicator...
IE, you pour into the hole, and when it overflows, it has enough in it.
this is the case on nearly all gearboxes, afaik
You could be right but why is there a metal pipe at the top that loops over & down. It isn't for the oil cooler, it's for something else.
Shaun
AFAIK you fill/check level through the filler on the side - the pipe on the top is a breather..
Yep just checked the manual - you fill/check through the filler plug on the side (looks like pass. side to me), and the pipe on the top is a breather..
Don't fill through the breather - if you do you'll overfill, and then you'll find oil coming out of that breather very rapidly when running, I believe...
