ABS sensor
Its looking like its one of my front ABS sensors that is causing my TC not to work. Is there anything I can do to fix it or is it get a new one time?
Do the Jap ones fit the UK and are they the same?
Stuart
Hello,
Move this back to the top, surely someone must know if a jap spec ABS sensor will fit a UK car, or have another answer, help the poor lad out!
Cos he's gonna need all the help he can get to try to keep up with me round the corners, heheheh ;P
you can remove the sensor and clean it also blow out any crap in the reluctor grooves. if you have a multimeter you can check the reading of the sensor(disconnected from main loom) whilst spinning the wheel to check if the sensor is working.or compare to the other wheel, sometimes the sensor will give an open circuit reading which will shut down the abs .
hope its some use to you.
[This message has been edited by syko (edited 27-11-2001).]
