Brake pedal hits the floor!
Just done the maiden voyage after doing the auto to manual conversion and i have no brakes! (It was a very short journey but it was my first clutch pedal and gear change experience in my little shortie:thumbup:!!)
When I depress the brake pedal I hear a hissing sound and the pedal goes very soft. When I start the engine the softness off the clutch pedal doesn't change.
Here's what I have done that may give a clue:-
Used the Manual brake servo and master cylinder from breaker.
Re-routed clutch/brake reservoirs using silicone (no pipe clips/clamps though)
Used the reservoir valves.
T'd clutch servo into Brake servo line in between one way valve and plenum.
Is it a leak? Valve wrong way round?
I hope it's something simple!!
Anyone experienced this before??
Thanks in advance,
Andy
like i said dude, connect the servos straight to the plenum with a check in the line, thus deleting the vac tank. if you still have a problem then, it's your servo. if the problem has gone, it's the vac tank or tank lines ;)
you can also disconnect the servo pipe and give it a blow through . if it blows out your servo is knackered
