Knocking Noise (probem 1)
PROBLEM:
Upon ignition I can hear a loudish kocking noise which stays throughout the drive but gets slightly less noisy.
AREA:
I got out of the car (engine still running) and it was more of a 'tinny' sound but it was coming from the back of the engine bay on the drivers side.
Is it a simple 'I need some more oil' (have done some miles recently) or something else?
Cheers,
Matty.
Have you checked the oil ? If not why not ??
Does the frequency of the noise change with engine speed or road speed ? (or neither)
Checked Oil, no problems there.
The noise is constant, tinney at the top of the engine....didn't sound as bad today (am going crazy?)
Matty.
So not a hydraulic lifter then, if it doesn't change with engine speed ??
(scratches head)
Am lost on this......or am I just being a 'Paranoid' Z owner...?
Matty.
This may sound a little crazy but if the sound remains constant even while you are reving, I would look to see if there is something loose. Maybe something metal is knocking on something else that is metal.
Just a suggestion.
