Front Camber Correction Kit Group Buy
I'm organising a group buy on Front Camber Correction Kits for all of us with front inside tyre wear.
A lot of Z's suffer from camber out of specs.
With too much negative camber the car doesn't drive in a straight line very well, has less tread on the road and the insides are worn out very fast.
The reason for this can be wear or damage in the suspension, the use of lowering springs or non-standard wheels.
This is an alignment problem which can't be solved at your local tyre centre because the camber can't be adjusted on a Z.
The Kit contains 4 brackets which replace the original ones, 20 shims for adjusting the camber in steps over a wide range (up to 2 degrees), two washers and instructions.
A table tells you how many shims to use once you have had your camber measured so should only need to be tested twice - before and after fitting.
All metal parts are laser cut and zinc electroplated.
The original nuts are re-used.
This kit should be able to deal with most camber problems.
I've got 3 people already wanting them so add your name to the list.
Almost everyone I know has this problem!
Price is £35 all in for 10 or more sets.
This is a bit of a bargain compared with the Stillen adjustable upper arms at over £400! If I'd got one of these kits earlier it would have saved £200 in otherwise un-worn tyres...
[This message has been edited by ChrisC (edited 01-09-2002).]
  • Replies 37
  • Views 1.5k
Yes,Please. 1 set for me!
Bloody hell Chris,I thought you ordered them weeks ago?
KEEP IT SIDEWAYS;).
Yes please if this is still open.
Please e-mither me with details if this is still on
day1zero@aol.com
I have ordered 10 with the option of more if required.
He was out of stock and is having a new batch made up at the moment.
They should be ready any time so let me know how many we want in total guys.
I'll have one please. Chris did you get that draft I sent you last month?
Cheers.
I'll check if I got it mate.
Chances are my girlfriend intercepted it and put it in the joint account cheeky *****!
Either way I'll send out the bits.
My Z is having problems driving straight. Wheel alignment not out and tyre pressure is OK. The camber was out according to the tyre place. How do you fit this correction kit?
First get your camber checked out to find out how far out it is, then all you need to do is look at the chart to see how many shims are required to correct your problem.
Unbolt the upper arms from the bracket, insert the shims then re-assemble.
Re-check the camber to confirm all is well.
This is a write up on the adjustable arms but steps 1 - 4 are what's required...
http://www.twinturbo.net/ttnettech/aarms/aarms.html
I'm going to place the final order this Sat 7th Sept and I'll mail everyone with details before then to confirm.
Add yourselves to the list.
I've got 9 people so far.
[This message has been edited by ChrisC (edited 03-09-2002).]
Me too mate!
"I think we should take Iraq and Iran and combine them into
one country and call it Irate. All the pissed off people live
in one place and get it over with."
Denis Leary
Yes please Chris, i cant make them myself for that!
How do we pay ?
Beer vouchers, hail marys, or cheque. LOL.
harve
yep me too, are you picking your car up this week i can give you the money for them if you are.
15 sets and counting.
This is going to cost me about £500 squids! LOL
I'll mail everyone with my address to send cheques at the end of the week.
[This message has been edited by ChrisC (edited 05-09-2002).]
Any last orders?
I'll order a couple of spares but will be mailing everyone over the weekend with my address and payment details so tomorrow is your last chance.
Hope im not too late too jump on the bandwagon! Ill have a set too.
yes please chris, put s set aside for me.
cheers
steve
me too
thanx
I'm in.
Kin hell! 21 sets now... is this the forum group buy record? LOL biggrin.gif
