Tunning
May help if you tell us more about your Zed, what is it N/A/TT etc, Mods & Spec?? Pics??
Regards Kim
Oh, and welcome to the Forum. :cool2:
lol my bad im new 2 this, its a 300zx twin turbo, dnt no much bout it got it yesturday :). just lookin to get a regular tune up :) thanks kim
well you first port of call would be a good service
oil change
filters
plugs
cambelt/waterpump if needed (60k or 5 years)
check for boost leaks
consult check
all the above should get you running somewhere near factory and im sure that 90% of zeds out there would see a significant performance increase from where they were. if the car is an ex forum members car then chances are it has been better maintained and should be running quite well already
next would be a cat back exhaust and performance filter which should see you well over 300hp
a chip, downpipe/turbo elbows, boost jets and a remap would see you about as far as you can go on a budget but should net you around 360-380hp
by this time the clutch (if its a manual) will be having some trouble so budget for an uprated item. if its an auto and in good nick you should be ok as long as the oil is kept nice and clean- an aditional auto cooler will be needed if its an import
also dont forget the suspension/brakes/tyres, these cars are getting on for 20 years old and with near on 400 hp you will be wanteing to stop and corner well
that should keep you busy and welcome to the club
