rebuilding throttle Bodies
Hi,
I have a boost leak from the butterfly shaft seal, can they be rebuilt with fresh seals?
Secondly, can someone with a TB hangin around measure the stock size of the seal. I'm running larger TB's but am hoping that the seals are the same.
Dimensions of mine are
I.D 10mm
O.D 18mm
Thanks!
Hi,
I.D 10mm
O.D 18mm
Thanks!
Have a couple of TB in the garage will go and check in while
