PCV valves
The car i bought is smoking a bit. I thought it was the turbos, but reading on here i want to change the PCV valves first.
Where can i get them from, and how hard are they to fit??
Nissan part only so Mike at MJP in the traders section - be sure to replace the hoses too as these get hard & brittle with age. Not too bad a job. Plenty of write ups on this :)
just make sure you have a long extension bar for your ratchet from memory the one side you need to have ratchet at rear of the engine to loosen valve
