no power to stereo
Since getting car back i had no.power to stereo. I remember a blue live cable running frm battery to stereo before car went in and decided to hook it back up. Had power.for 5 mins but since then.....nothing. i have changed fuse on stereo and the fuse in drivers footwell but still no luck :(
Dang! Still cant get pwer to music. Luckly my new convertedml manual has now got a sexy burble when decelarating
Some have an fuse inside , plus is there a fuse in the rear of the casing
ahh. ive changed the fuse on the back of the case and in drivers footwell but didnt know about one inside stereo
Maybe you have live supply but a bad or missing earth, need to check with a multimeter.
Jeff
use a test light on the feeds to the radio one will be permenant live one when ignition on earth best way is to run a new wire from the radio earth to one of the bolts behind the dash to check it is earthed connect test light to it and check the live feed again
plug all back in should work
all the best
