anybody replaced pas ecu?
Seem to still have an issue where as my steering gets so haevy [usualy when trying to park] that its like the car has stalled!!!
Replaced solinoid on rack drain flushed system twice looked threw search and there is a mention of a ecu for steering ....so thought i would ask:tt2:
Dave
Dave just a thought, it may be a speed fault on the sensor circut and the car thinks its doing 160mpm so giving hard steering.
Allan
Whats the harm in trying a different ECU? It'll be an easy 10minute job and the cost of one from a breaker will be peanuts.
Give it a whirl if you think it might solve the problem, the worst you'll loose is £10/15.
Personally though, I think its unlikely to solve your problem. Is your speedo working correctly?? because this is where the PAS ecu gets its signal from NOT directly from the speed sensor.
Allan
Hi Allan would you know how to check this out for faults??
Speedo is spot on matey
