Front top suspension arm nut sizes, (diagram provided)
Anyone happen to know the nut thread sizes for these nuts on the front top arm?
I want to replace the nuts as the oem ones are a bit long and bind on the aftermarket arm due to the amount of lowering.
these are the ones in question:
cheers vijay i will buy one of these, im sure it will help in the future, im forever faffing about with nuts and bolts.
Jimmy, have you done anything to correct the roll centre given how much you've lowered the car?
Im working on that now, heres my first step: I was going to buy those spl steering rods but they are taking to long. Im going to make my own with my old tension rods kinda like what unique zed has done, so the steering arms are at a less funky angle.
What have you done Jaffa?
not done anything on mine yet, but it isn't hugely lowered either.
Was looking at the driftworks hubs which lower the car by around 50mm but keeps all the geometry in line, not sure if they'll work on the 300 though.
Yeah i have seen those, £700 or so. Give them a call see what the say, they are obviously 200sx fitment, the r32 has the same setup as the 300 so if they fit an r32 they should fit the 300.
from the website:
Regarding fitment
This product is a direct fit for Nissan 200sx/Silvia S14 and S15. It is possible to fit to an S13 with the information below.
from the website:
Regarding fitment
If its any help i know Tension rods on a S13 is the same as a 300. And im sure most of the arms are the same.
Again im not sure if this is any help: http://www.houston240sx.com/showthread.php?p=662415
Most likely not, but there you go :)
