protoj · 15 hours ago 15 hr
Hi All,
When I depress the clutch it drains all the fluid. Therefore, I am shortly going to replace the master and slave clutch cylinder and fit a braided clutch line.
Does anyone know how difficult it is to access the cylinders?
Is there anything else that I should change/uprate whilst doing this?
Many thanks in advance,
Tom
