September 9, 200224 yr Plug and play speed delimiter. OIRO £65 Tim [This message has been edited by TT Tim (edited 13-09-2002).]
September 9, 200224 yr Thats what i need i think,,,i thought i had one fitted but i can not use the cruise control over 65 so guess not. How easy is it to fit etc??? mods to ecu etc???
September 9, 200224 yr At a risk of shooting myself in the foot, I'm not sure that this will remove that restriction, this is designed to remove the 112mph top speed limiter that is applied, by law, to JSpec cars, it might alter the Cruise control parameters but I think that might be a secondary feature. You could use this if, your car is: a) Jap Spec and b) limited to 112mph? As for fitting, remove the plywood pannel in the passenger footwell, unscrew the ECU connector, replace with Speed DeLimited and screw it all back together. The only tools to will need is a x-head screwdriver and a 10mm spanner. HTH Tim
OIRO £65
Tim
