anybody know where i can get a quote for an engine block to be done in or around dorset/hampshire. i can only find ones upt norf!
cheers
gaz
Blimey, thats a bit OTT. Why would you want that done ? a normal hot clean does the trick. If your still feeling flush cos it wont be cheap, there's a company that I have used to cryogenically clean armatures on marine generators in Southampton called Dowding & Mills. I'd be laying down when you call them tho'.
Thanks for your reply. Its not for cleaning its for strength. Cryo treatment is used in the motorsport industry. It seems to have the best effect On ferrous metals. I want to give the block im using the best chance of life. Found companies like frozen solid but they are too far away:)
