can anybody explain
how this still insists on remaining attached to my zed...
Uploaded with ImageShack.us
i did read a few threads on here on how to remove hicas ball joints, and i started off grinding down the ball joints to knock through with a hammer etc but they wouldnt budge so i thought i`d try and drill through to hopfully release some pressure (not sure if that was a good idea or not) but now im at this point..any ideas?? lol.
thanks for the reply, i think i may have to tomorrow, i did initially want to stay away from heat as i didnt want to warp it in anyway. but i am running out of ideas rather quickly now lol. appreciate the info
how much heat do you recon it should need?? approx?? unsure if thats a silly question but just i dont fancy replacing the hub anytime soon, lol.
thanks
just keep trying a bit of heat and keep knocking till it starts to move
make a heatsheild out of some metal so you can protect any other parts from heat
well aluminium has a lowish melting point so you dont want to use an oxy acetaline on it but a hairdryer wont do. something like a plumbing torch should do. you could also make a puller out of a large bolt and a large socket.
