front bumper washers
I wanted to do away with the front bumper washer hoses, if I pull the hose out the res. it just leaks everywhere. Guess I need a bung of some sort. Whats the best way to ditch those.
Remove the power to the large pump. Leave a small amount of pipe on the pump and insert two bolts into the remaining lengths of the pipe and secure with jubilee clips until someone can advice you of a better way.
You could get a jap-spec washer bottle, that will eliminate the requirement for headlamp washers.
