Fuel Pump Relay
If I remove the fuel pump fuse/relay thing in the small fuse box on the drivers side under the bonnet, the engine should stop am I correct? Or have I removed the wrong thing?
yeah I thought so, I did double check the fuse box lid. All I want to do is change the fuel damper so thought it would be best to let it drain the fuel out of the old one first and the pipes before I took the old fuel damper out!
