Rear brake set up
Hi
Got k sport set up on the front that makes the back look a bit weedy
Got 18's on her at the mo just wondered if there is any cheap conversion
that will look better.ie maybe a larger fancier disc with a bracket to move the calliper out a bit ??? or possibly a larger set up fm another nissan with a bigger calliper that will bolt straight on ?
thks Kurt
skyline brembo with some bigger disks and brackets to move the caliper out to match
Try dan, send an email though half the stuff he does aint on the website, the brembo brake pistons are 1mm smaller than the stock z but the brembo pads have better coverage of the disk (If the internet is right )
http://www.db-power.co.uk/index2.php?page=home
cheers dan
but need to spend money on other things surely parts off another car must fit even with an adapter ??
you could try a pair of 350 z discs i think db power do a kit
Edited by dougal200
