Info needed please anyone
Took my zed for a drive out today when I got
Back, find rusty water leaking from under The drivers side,(near gearbox), where is this water coming from has anybody else had any probs like this?
Give us a clue matey, are you saying from outside the car or in? Have you checked your coolant level? Check the two main heater matrix pipes that run from the back of the engine onto the heater matrix pipes on the engine bay bulk head. Also have you had the the water pipe bypass carried out under the plenum?
Yep looking from outside under the drivers side, yes the water bypass got done by zworld.
Will check matrix pipes, cheers.
more likely to be your water pipes that go to your matrix. Nice easy fix.
You can get the pipes off mike :)
Hi guys looked at the bulk head and the pipes seem to be okay there is no water marks also around the gearbox, or around the back of the engine? Had to top the rad up a small bit but not a lot! Any more things what to look for please!!
Hi guys just had a look again with the engine running and the top matrix pipe is leaking directly to the floor, I've got the top one end off the engine side but how do you get to the bulk head side without having very very small hands, also would you change both of Tthe matrix pipes? Cheers Paul.
tiny hands matey! it is very awkward, there are a few things you can remove i think to make it a bit easier, i changed the clips for good jubilee clips when i did mine, that way you can get a long screw driver down there to tighten them up, rather than warrioring with those horrible clips... and you might as well change them both whilst your at it...
did mine not hard job, fairy liquid, , do both pipes ,
oh yes and u will lose a few layers of skin
YES i can confirm my hands have lost a few layers of skin, but there off!:clap:
New silicon pipes ordered. Thanks guys for info Paul.:clap:
