What power am i going to expect??
Hi ive been thinking for some time now with very mixed views on what sort of power i will be expecting once the car is finished.
I would like around 600bhp at the fly what do you guys think? No idea on torque.
New spec list to date:
Engine mod's:
GT28RS turbo's (Disco potato)
HKS actuators,
Greg dupree inconel exhaust manifolds,
Greg dupree Specially Z 3" Stainless steel split down pipes,
Greg dupree 3" flexi de-cats,
Haward & Scott rear boxes,
Ported & skimmed heads,
Ported plenum,
Ported inlet manifold,
JWT 400+ aggressive race cams,
JWT heavy duty vtc springs,
Wiseco pistons 88.0 slight over bore,
Eagle H beam Con Rods,
ACL Race spec shells,
Cometic .45 multi layer metal head gaskets,
Z1 Re-build kit,
Z1 Oil pump,
Z1 Water pump,
ARP Head & Main stud kit,
Unorthodox lightened crank pulley,
AMS water pump pulley,
AMS alternator pulley,
AMS power steering pulley,
Greddy kevlar aramide cam belt,
HKS spark plugs,
Nismo grounding kit,
Smithy's IAA valve pipe,
Custom made engine mounts,
Z1 stainless steel bolt kit
Z1 turbo oil return lines,
Z1 turbo oil feed lines,
Battery relocated to the boot,
DTA polished batt tie down,
Cooling:
Ceramic coated turbos and manifolds,
Greddy 3 row Spec-R FMIC,
Greddy twin airnex filters,
Greddy grex 10 row oil cooler,
Greddy sand which plate,
Greddy braided oil lines,
Greddy Oil catch tank,
Koyo uprated aluminium radiator,
Koyo polished rad bracket,
Z1 Stainless steel Lower hard pipe,
Z1 full hard pipe kit + silicon's,
Nismo thermostat,
Nismo high pressure oil & rad caps,
Doolz air filter set-up,
Doolz v 2 FMIC extensions,
HKS SSQV Blow off valves,
Smithy's carbon fibre throttle body cover,
Smithy's carbon fibre air guide and light covers,
Carbon fibre fan shroud,
Carbon fibre large/small fuse covers,
Braided oil & power steering lines.
Reflector GOLD heat shields on oil, water lines.
DEI heat wraps.
Fuel system:
Sard adjustable fuel regulator,
Nismo 740cc injectors,
300 degree high flow fuel rail,
Walbro 255ltr fuel pumps,
Braided fuel lines thoughout.
Electronics:
DD2 digital stack dash,
AEM ems uego stand alone ecu,
AEM uego Air/Fuel guage
AEM uego Multi series guage,
AEM 3.5 map sensor,
Greddy type 2 turbo timer,
Apexi avc R boost controller (ltd),
Race logic performance meter,
Race logic digital traction control with launch control,
Integral det sensor system with display for vg30dett,
Edited by GIBSTER-TT
I think your gready :lol:
Fitted my injectors today and im more than happy :lol:
I think you will get about 20hp from the magic tree :wink:
Well I can tell you that if mine is anything to go by, you can expect two gallons to the mile same as a sherman tank and im not kidding lol
Engine mod's:
HKS actuators,
Ported plenum,
Z1 Re-build kit,
Z1 Oil pump,
Z1 Water pump,
HKS spark plugs,
Cooling:
Nismo thermostat,
DEI heat wraps.
Fuel system:
Electronics:
AEM 3.5 map sensor,
Drive chain:
Quaife ATB diff
N/A Ratio leader gears,
Nismo quick shift,
Exedy hyper twin plate clutch
Exedy hyper lightened flywheel,
Nismo clutch pivot ball,
1 Piece light weight prop with UJ's
Nismo poly bushes for steering rack & diff,
Nismo gearbox mount,
Smithy braided clutch lines,
Braided power steering lines.
Suspension/Brakes:
Buddy club race spec coilovers,
Stillen Hicas remover,
Z1 solid subframe bushes,
Powertrix adjustable drop links (front)
SPL adjustable camber arms (front)
Powertrix adjustable tension arms (front)
Powertrix adjustable camber arms (rear)
Powertrix adjustable traction rods (rear)
Stilllen adjustable anti roll bars,
Stillen rear strut brace,
Carbing front strut brace,
Zen garage brake cylinder brace,
350 Z Brembo calipers,
Dba 5000 brake discs (front)
Dba 4000 brake discs (rear)
DTA Braided Brake lines.
Wheels & Tyres
Rota light weight GTR'D alloys
Front 245/40/18 9.5j
Rear 275/35/18 10j
Toyo T1R Proxy tyres
Red light weight wheel nuts
Saving more weight by removing:
Air con system,
EGR system,
AIV system,
Carbon canister,
Plenum water bypass,
Removed PCV valve system,
Exterior mod's:
Bare metal re spray,
Rosso corsa red (Ferrari)
Modified ab-flug front bumper,
Bomex low level spoiler,
Bomex custom made carbon fibre high level spoiler,
Bomex rear skirt,
Viper vented wings,
Ab-flug side skirts,
Ab-flug light panel,
Veilside carbon wing mirrors,
Nissan Illusion rear light panel,
H.I.D conversion kit ,
99 spec rear lights.
Interior mod's:
Stripped out rear,
Custom made interior cobra daytona red/black trimmed seats,
Custom made carbon fibre dash,
Custom made carbon fibre panels,
Red sparco 3 point harnesses,
Snap off hub,
Sparco steering wheel,
Nismo gear knob,
Honda s2000 Ignition button, ,
Groovers Blue custom L.E.D conversion,
Custom 300zx mats,
Snooper S 3 radar detector and S 6 GPS,
Garmin 310 D satnav built into the dash,
Vanilla magic tree lol
Shopping list:
A Half roll cage.
Hawk kevlar brake pads.
Aem water injection system.
well after trawling through a load of piffle that had no bearing on horse power id say you may get detonation at high boost as your head gaskets are thin but if that plays ball you may see 500 at the wheels possibly.
Edited list!
Ive had this issue from the beginning the company who supplied the gaskets
I was told the gaskets would be ok due to todays tuning capabilities.
Ive always been unsure with this :(
I don't thing the head gasket on its own would be a huge problem but its not going to be helped by adding skimmed heads to it.
Will be very interested to see what it makes and when boost starts coming in, I'm sure you will still get very good power from that lot
Would you think the boost would come in earlier or later due to the compression??
Its not going to effect boost coming in your raising the compression ratio which is good for off boost but will probably require timing to be retarded a tad more when its mapped, as long as you entrust it to some one who knows what they are doing I'm sure you will end up with a very powerful Z
Thanks Fri1 ive sent an email to the supplier who originally supplied the gaskets and various other parts. At the time i raised the same question and he assured me it would be fine.
As ive had no experience in building engines ive relied on other people to help.
I just hope it all works ok after all this time building this Zed
impresive spec:yes:...and some serious wonga too:huh:
